Need Advice: broken ballast check valve
Replaced mine three years ago with check valves from a local irrigation supply house - same thing that came stock, 1/3 the price, and still working just fine!
I love wakemakers products, expect for there check valves. I had to replace all 6 valves in the first season. I picked up new check valves at Lowe's for a quick fix two seasons ago and haven't had any problems.
Leave a comment:
I'm surprised those PVC check valves have lasted this long.
Will these work? http://www.wakemakers.com/anti-siphon-check-valves
Leave a comment:
Short or replumbing, you will likely need to retain a check valve. I would go with an actual marine check valve as opposed to those irrigation valves found at hardware stores.
Leave a comment:
One of my check valves is cracked and leaking into engine compartment bilge. I believe its the check valve on the bag fill side of the ballast manifold.
Is there a better solution than just replacing that check valve with a new one?
If there's not a better solution, where's the best place to get one?
Thanks!
Leave a comment:
