The one I had is like this
https://marinesan.com/1-npt-y-valve-...astic%20Handle
2006 X2 Bow Ballast Bag Draining
Excellent!
Would you happen to have a part number or pic of said in-line valve??
Thank you!
Originally posted by Keep on Tryin' View PostI had an old in-line valve laying around that I put in the supply line right before the KGB. I filled everything up then shut the valve. The bow sac / kgb did not leak, so I determined it had to be in the supply hose.
Leave a comment:
Originally posted by Hawgdriver View PostThis season…
But wouldn’t the water drain out the intake rather than into the hull?
Yes a bad impeller would drain out the intake under the boat.
Sent from my SM-G965W using Tapatalk
Leave a comment:
Leave a comment:
How did you diagnose?
Or did you just happen to replace that section of hose and noticed it was cracked?
Originally posted by Keep on Tryin' View PostI was having a similar issue on my 2006 X30. I thought my KGB tank was cracked.
It turned out there was slow leak as the result of a crack in the original fill line to the KGB (old and dry-rotted).
Replaced the hose, and no more issues.
Leave a comment:
Leave a comment:
This season…
Originally posted by WolverineFW View PostWhen is the last time you changed the pump impeller? If it is too worn water will leak back out when the pump is off.
Leave a comment:
Leave a comment:
I have a X2 with a plug and play bow ballast bag that’s draining without me emptying it. I can’t see anywhere that it’s leaking.
My initial indication of the bag draining was my aft bilge running and emptying water from the hull while we were surfing.
I’m sure I’m missing something but what is it?
None of the fittings are loose.
There is no wet carpet clues.
My only guess is a cracked KGB (factory center tank that feeds into the bow bag).
I do not know how to confirm this possibility.
Can anyone offer some more ideas on ways to find the cause?Last edited by Hawgdriver; 07-24-2021, 01:14 AM.
Leave a comment:
