2016 NXT22 fuel pump problem.
  • Greenwood87
    replied
    I found the problem, it blew 2 10 amp fuses that was on the drivers side of the motor. They were way down in the bilge.
    Leave a comment:
  • Greenwood87
    started a topic 2016 NXT22 fuel pump problem.
    It’s been a while since I posed here. But I’m at a loss on what’s going on with my boat. 2016 NXT22 with the MV8.
    Took it out for the first time after de winterizing (oil change and new impeller). The boat wouldn’t start at the landing. Got it back home and no fuel pressure at the rails. Checked neutral switch and safety switch they both are functional. Fuel pumps were not running. Pulled the Millennium unit. Bench tested both pumps and they were not functional. Replaced the fuel pumps and tested to make sure the new ones were working.
    Now there is no power at the plug that goes to the Millennium unit. I didn’t check it before I replaced the pumps. No engine codes. Swapped the relays at the engine. Checked all the fuses and breakers. Still no power.
    I’m starting to think it may be the ECM. Anyone have anything that could help.
