There is a similar discussion going on here: http://www.tmcowners.com/teamtalk/showthread.php?t=6569
I'm getting ready to install dual batteries in my Prostar 190 and I'm planning on using a different isolator/combiner. Specifically this unit: http://www.yandina.com/c100Info.htm
I believe there is one drawback to using a "dumb" relay. When the key is switched to ON the batteries are immediately placed in parallel. If one of the batteries is significantly drained it will pull the other battery down and equalize at a voltage level somewhere in the middle. This could all happen between the key hitting ON and START. Potentially the voltage could drop low enough to prevent the boat from starting. I have never had this happen but I think it is theoretically possible.
The Yandina combiner only places the batteries in parallel when one of the batteries reaches 13 volts, ie it is being charged. This only happens when the alternator is turning, ie the boat is running. So starting the boat will drop the voltage of the starting battery down, once the alternator has it fully recharged, the batteries are placed in parallel to allow the aux battery to charge.
I'm not trying to knock the method above, obviously it works very well. Just throwing out another alternative. I'll draw up a diagram for the setup I'm planning and post it.
The Official Dual Battery Thread
Guest repliedRobert; YOu can put a VOM that reads current in series with the positive lead off a charged battery. With everything off you should see some current draw if your battery is being killed. Then you will have to find that problem!
Leave a comment:
Not wanting to complicate things further, but is there a easy way to diagnose current drain? I bought a new battery a few months ago, and have not used it since other than just a few tests on my sound system.
My battery is dead again.
I have not disconnected it and trickle charged it though.
Any ideas gurus??
Leave a comment:
I am very inexperienced with this type of thing. Can someone please explain in detail exactly how to connect the relay to the ignition circuit? I would really appreciate it!
Also, is it going to be a problem if I keep the battery that I have now for starting, and add a blue top D34M for accessories? All I know about the battery I have now is a one year old deep cycle marine battery, but is not a blue top.
Leave a comment:
Guest repliedOriginally posted by DieselNo need to isolate the third battery or the forth, fifth, etc.............. The isolation only protects the starting battery from draining while running the stereo. The isolation ensures you will always have a fresh battery for the engine.
Just wire the third battery in parallel to the auxiliary battery. This way the isolator still only sees one big 12 volt battery. I would recommend that you buy two new identical batteries to prevent current disparencies between the hardwired batteries. In addition if I know I am not going to be using my boat for a month or longer I will disconnect one of the terminals connecting the two auxiliary batteries to prevent current flow between the batteries.
Also make sure you do not overload the capacity of your isolation device. Double check the rating and measure your current draw from the 5 amps to ensure the isolator is not overloaded.
Leave a comment:
Originally posted by skitilldarkNot to compicate this thread, but how about adding a third battery? For 2 years I've had two batteries with just a simple isolator switch between the two. They worked great overall and no problems with the alternator. But last year, I added a 5th amp to the mix and I'm almost positive I'm overtaxing the Optima that is supposed to run the stereo. If I add another Optima, would it be okay to just wire those two together, or should I isolate them as well?
Leave a comment:
Guest repliedNot to compicate this thread, but how about adding a third battery? For 2 years I've had two batteries with just a simple isolator switch between the two. They worked great overall and no problems with the alternator. But last year, I added a 5th amp to the mix and I'm almost positive I'm overtaxing the Optima that is supposed to run the stereo. If I add another Optima, would it be okay to just wire those two together, or should I isolate them as well?
Leave a comment:
Diesel,
Can you repost the pictures you had in this thread? Do you have a picture of where you relocated your batteries to? It thought I remember you saying you relocated them to you bilge compartment.
Thanks
Andy
Leave a comment:
Originally posted by greggSorry, yes I did mean 2 amplifiers, mtx280 for the sub, and jl audio for the componants and tower speakers, 80 to 100 amp draw, at boat to beach volumn levels, so my system is a bit smaller than yours. I would still debate the theory of the amps or volts traveling between batteries unless one of the batteries had an internal short or drain. The batteries are discharged and charged equally, so there is no amperage flow of any kind. For sure a bad battery would ruin a good battery, which is why they should always be replace in pairs. For the voltage to push the amperage, the amperage has to have a load or place to go( light, amplifier ect.). The bottom line is even though these are deep cycle batteries and meant to run accessories for long periods of time, the deeper you drain or cycle them the shorter the life due to heat and sulfation of the plates. In my opinion or theory if you will, your system would actually work your batteries harder because you could and probably do completely discharge one of your batteries. When you start your boat and connect your batteries together, not only is your alternator charging your low battery, but your full battery is also transfering amperage into your low battery. Again, I am not saying your system is wrong or mine is right, just a different way getting one thing done..enjoying great tunes on a hot day with a cold beer!!
Leave a comment:
Leave a comment:
Originally posted by DieselGood comments.............
The only issue I have with not isolating a parallel set of batteries is the continous voltage flow between the batteries. This is a non-issue in most vehicles (including diesels) because they are driven frequently. As a result the alternator has an opportunity to keep both batteries at full voltage to minimize discharge between the two batteries. Since a boat is not driven every day two batteries stored in parallel will eventually destroy each other.
In addition it is easy to see why you have never drained the two batteries since your stereo is only pulling two amps. At 90% my current system will pull 165 amps
. I can drain two brand new optima blue tops in 3 hours very easily.
As a result, isolation not only give me the security of knowing I can make it back to the dock but it also gives me the security of knowing the two batteries are not going to kill themselves.
Leave a comment:
Originally posted by bcampbe7I think he may have meant 2 amplifiers. Maybe not, just my thinking. At any rate, thanks for the write-up Diesel! I am wanting to add a battery, this will come in very handy.I knew there was no way he had a stereo that only pulled 2 amps
. Your explanation makes so much more sense.........thanks
Leave a comment:
Leave a comment:
Originally posted by greggDual battery systems do not have to isolated to be effective. If the system you use works, then stick with it. I, too, debated about the best way, and with 30 years experiance in the automotive repair field I know that, for example diesel trucks with a dual battery set up use no relays to seperate the batteries. What they do, that is different, and the way my batteries are connected is very simple. The positive cables to the boat are connected to the positive post of the main battery. The negative cables to the boat are connected to the negative post of the second battery. Then, the batteries are connected together in parallel. This does one very important thing. The batteries are discharged and charged evenly. The biggest enemy in a Marine battery's life, are number of cycles (discharging and recharging) and heat. When you isolate one battery and discharge it completely, it has not only been thru one deep cycle, but also creates more internal heat in the recharge process.
Diesel, I am in no way saying your system is wrong. I decided after my own experiance and research, and a pow wow with my Interstate Battery rep.(who knows batteries inside and out), that this system works the best for me. Even after a day at the beach running 2 amps, I have never had an issue. You are right about one thing, if you poop both batteries, you are screwed, so I just keep a booster pack charged and on board just in case. However, in 3 seasons with my 2002 maristar 210 have never had to use it. The other important thing for a marine battery is to keep it fully charged in the off season. When a battery becomes discharged, the acid absorbs into the plates causing sulfation, and leaves the water in a state that will freeze.
Leave a comment:
Leave a comment:
