Has anyone heard that Indmar is requiring 10 (not 8) quarts of oil for the L-18 motor? My dealer told me that Indmar published a service information letter stating that all L-18 motors need 10 quarts of oil rather than 8 quarts. They are sending new dip sticks to the dealers showing a new "full" line corresponding to the 10 quart requirement.
My question is: if the oil pan was designed to hold 8 quarts, would putting 10 quarts in this same pan cause the front or rear main seals to blow out or leak? My L-18 uses a little oil but I always check it and add more if necessary. I don't want to "fix" one problem only to create another.
