Are Chevy 350's found in Mastercrafts standard or reverse rotation?
  • Engine Nut
    replied
    Originally posted by Wake_USF
    Good call! Why didnt I think of that!
    Potential problem:
    Lets say the boat/tranny/prop we have is standard.....what are the chances our donor motor is the opposite? We got the donor motor from a i/o cutty cabin boat.
    If the donor motor came from a sterndrive application it is a standard, counterclockwise rotation engine. GM Used to build right hand rotation engines but they are no longer available as production items. The advent of marine transmissions and sterndrives that can live up to full power in forward or reverse eliminated the need. We still build a few RH engines that are used for repowers in some older boats.
    Leave a comment:
  • Wake_USF
    replied
    Yeah, I know....we are working on it! Its only been up for a few weeks.
    Leave a comment:
  • Hollywood
    replied
    www.wakeusf.com is painfully slow!
    Leave a comment:
  • TMCNo1
    replied
    I don't know if anyone here know about engines, but..................
    Leave a comment:
  • JimN
    replied
    Standard rotation. Look at the tab with the timing marks- BTDC is above the zero.
    Leave a comment:
  • cbryan70
    replied
    im not sure if the tranny will say, but he will know or someone with ALOT more knowledge then me will know
    Leave a comment:
  • cbryan70
    replied
    will your tranny hook up to it? pm engine nut he will beable to tell you everything and anything you need to know
    Leave a comment:
  • Wake_USF
    replied
    Potential problem:
    Leave a comment:
  • cbryan70
    replied
    what rotation prop do you have on your boat? They are either or some or RH some are LH i believe
    Leave a comment:
  • Are Chevy 350's found in Mastercrafts standard or reverse rotation?
    Trying the rebuild the clubs boat and I was wondering if they are standard or reverse rotation.....anyone know?
