Originally posted by mtajpa
View Post
2001 Maristar Tranny Q's
Turns out, once the allen key loosened up, the rest was pretty straight forward. Used needle nose pliers to grab the tab that says "ATF" and it popped right off. Then the rubber gasket popped out and out came the filter, again, using the needle nose to pull it out. Sure enough, there was some sort of hair / mesh that the filter had caught...pretty big chunk (quarter size and about as thick as an eraser on a no. 2 pencil). I'm sure it had never been out as the paint over the entire assembly had never been broken...13 yrs with the filter never cleaned....pulling the plug next. Thank you very much for the help.
Leave a comment:
Thanking you! I'm getting after it today and hopefully not cause too much damage.
Leave a comment:
The allen screw is what tightens the seal. Mine was difficult to get off also. It will come out. But what may happen first is that the cap starts to move with it.
Found this comment on the link below.
The cap has an allen head bolt on the top. It says "tighten"; "Pull - Loosen"; "Push - Tighten" on it. There is also a tab on the cap that says "ATF". One would insert the allen wrench, turn counterclockwise until the "ATF" tab hits the transmission housing, then continue to loosen the allen head. This will decompress the large o-ring inside the cap. Then, one should be able to just pull the cap off. The only thing that holds the cap on is the compression of the o-ring. I couldn't break the allen head free - so I had to pry out the cap (not recommended). At the time, I didn't realize it was o-ring compression that held the cap on.
Leave a comment:
Mtajpa (or anyone who is more mechanically inclined than I am)- thanks for the pics!! I've been struggling for years with the same problem that wakescene has had. I've always sucked it out and wondered where all of the fluid is...anyway, to remove the lid / cap next to the zf hurth tag, there is an allen key cap and just below that it looks like a little tab that actually says "ATF" and "tighten" / "loosen". That allen key top is wearing me out as I cannot seem to get it to loosen up - in fact, I'm positive that it hasn't been removed for the almost 6 yrs that I've owned the boat. Any secrets on that part of it?? Thank you.
Leave a comment:
If you suck out the fluid thru the filter housing, by removing the filter you can get all of the fluid out, even remove the actual drain plug at the bottom and catch the remaining fluid in a shallow pan. On mine I sucked the fluid into two 2 liter soda bottles. Replaced with the same amount as I sucked out.
Leave a comment:
Thanks both. I'll give Indmar a call and also look for the other drain.
Thanks
Leave a comment:
Originally posted by bigmacProbably better off calling Indmar. They'd know. Although if your tranny says 630V, it's going to be 4.2 quarts.
Leave a comment:
Originally posted by wakesceneI think I found the model...but not 100%. I found a sticker but this was on the adapter plate for the tranny to the motor.
On the dipstick however, I found the numbers 630 V1-HSW... This is a V-Drive so I am assuming that the 4.2Qts will be correct. I guess the only way to figure out what is correct is to fill up a few Qts and then sample sample sample till the level is correct and note what I have added.
Anyone (bigMac perhaps) have a number for Hurth.
Would calling MC help here? Should they have record of what was installed into my boat?
Leave a comment:
Leave a comment:
I appreciate the help. I'll locate the plate and get the correct model, ensure it's drained fully then start adding in the correct amount of fluid. I suspect I have been running low, although I have had not problems with the unit in all the years of ownership. Previous maintenance by certain dealers was sub-par and I decided to take it on. Have saved a lot of money as well as getting maintenance done when needed or at the first onset of an issue.
Thanks again for the help.
KG
Leave a comment:
Originally posted by wakesceneThanks BigMac.
1 Issue though. I have been doing my fluid changes for 3 years now and I was only removing about 2Qts from my tranny. It's a V-drive and that list you posted shows it requiring 4+Qts. I have never pulled more than 2.5Qts out of my unit. In the fall when I did my winterization I pulled 2Qts out. When I started to add new fluid, I ended up adding in 3.5Qts. I began to question things and remove some fluid. This past weekend I fully drained the tranny and was curious about the actual amount I needed to add to be correct. Seeing that it is dry right now it should be easy. I guess I really need to determine what model I have and then go from there.
I fear that the previous maintenance was done poorly...which is not completely out of the question, hence the reason I have been doing it for the last several years.
630V is the Simplicity number for the ZF Hurth 1.5:1 V-drive...the Hurth number is VF-63IV. That's the number you'd find on the ID plate on the front of the transmission. That transmission calls for 4.2 quarts of either Dexron or 15W40 , your choice.Last edited by bigmac; 04-07-2008, 02:52 PM.
Leave a comment:
Thanks BigMac.
Leave a comment:
Leave a comment:
