I have a 351 w/carb on a Maristar. 330 hours. I've owned it 7 years and it's been great up to now. Boat starts up easily and idles. If I give it full throttle out of the hole, it will not take off: it sputters and runs rough. This happens warm or cold. If I plane the boat out slowly, then give it full throttle it takes off and sounds great.
The boat ran fine last year. This problem started new this year. I took it out first time and noticed problem. There was no water in the water fuel separator (I replaced it with the in-line filter too). The screens in the carb were perfectly clean. I cleaned the flame arrestor too. I changed the spark plugs before taking it out the first time this year. One plug did not have any engine fogging oil residue from winterization; the remaining 7 plugs were all oily from winterization. No remedy has worked. The marina has worked on it all week and cannot fix it: they say the ignition checks out ok and see nothing wrong with carb. I burned 13 gallons of new gas this year. I had the tank a little low at winterization with stabilizer.
As a maintenance item, last summer I cleaned the gas tank, and I took out the screen in the tank pickup. I also removed the anti-syphon valve at the tank.
Any ideas?
Any ideas?
