Fuel pump aftermarket part numbers
  • Fuel pump aftermarket part numbers
    After a bit of research i replaced the pump on my fuel module with an aftermarket one from NAPA. Here is the part I used and a few others that other people have used to avoid having to replace the whole module.
    Fuel pumps:
    NAPA E2065 45 GPH 90-95 psi. (Canadian NAPA part number)
    ACDelco ep356
    Advance Auto Parts E2044
    Unfortunately US and Canadian NAPA parts have different part numbers if you can believe it. I don't now what that NAPA part crosses to in US NAPA.
    This is for information purposes only. Please use these parts and info at your own risk.
    sigpic
    04 197 TT LQ9 stargazer w/Z-Box
    Tournament PB 1/4 buoy @ 35 off
    Previous...
    96 Prostar 205 Lt1
    93 Prostar 205 HO
    81 Leaves and stripes(Can. edition)
    Pump replacement
    I would like to thank you and others for the work you have done to work around the MC fuel pump issue. I feel we should also post the engine year and model along with the pump removed to verify compatibility with the Delco EP356 and other brands at the 56 psi output.
    Mine is a 2000 Maristar 330 LTR with a Carter 323 2H22B or 8 pump.
    I talked to Federal Mogul and was told the pump is a MC design and they build it only for MC. He would not give any specifics of the pump IE (output pressure).
    Is the EP356 or equivalent pump adequate for this motor? I would appreciate any input. Thanks.
      The NAPA pump E2065 that i used was for an 04 197 with LQ9. The fuel module has the Carter number 71-341s on the top of it.
      I am not sure but i think that all the engines from 03-06 use the same style of in tank fuel module. Each boat has a different part number because the fuel tanks differ in size and shape from model to model.
      BUT...i still think they all use the same actual pump.(Not 100% on that)
      Anyone who could confirm this would be great.
      sigpic
      Previous...
      96 Prostar 205 Lt1
      93 Prostar 205 HO
        Pump
        I saw the pictures of your replacement on another post but was unable to read the numbers on the pump. If you could post the numbers on the carter pump it would help .
        jpmaristar
          I will check this afternoon but the number is Carter specific and does not really cross reference to anything as far as i can see.
          sigpic
          Previous...
          96 Prostar 205 Lt1
          93 Prostar 205 HO
            rhs, I am afraid that the only way to confirm/verify that the pump in all of the modules is the same is to get that information from Carter/Federal Mogul or MC. And I will give you one guess if they will cough up that information.
            I would be willing to bet that the pump is the same and the difference in MC part numbers for the different boats is just as you said; they differ based on the design/shape of the different fuel tanks.
            The output pressure is not important unless for some reason it was below 58 psi. The regulator decreases the pressure to 58 psi.
            There do appear to be other differences. I have seen some of the systems that use a returnless system (only one fuel line connected to the fuel tank/regulator) and others with 2 lines. I am not entirely familiar with these 2 line systems. But, as far as pumps are concerned, I think that is a moot point.
            Common sense is the least common of all the senses.
              Pump
              I was trying to verify if your Carter pump had the same numbers stamped on it . My dead one reads 323 made in USA and 2H22B Carter.
              Thanks for the reply,
              jpmaristar
                jpmaristar
                mine has 323 MADE IN THE USA
                41C11C CARTER
                stamped on it.
                Mine is from an 04 LQ9 motor
                What boat and motor do you have?
                sigpic
                Previous...
                96 Prostar 205 Lt1
                93 Prostar 205 HO
                  Thanks for all this GREAt info. My pump fried last weekend and I was told that a new pump from MasterCraft was on Back Order and that it would cost ~$450. After reading this post, and others, I went down to the local AC Delco distributor and for $141 replaced the pump. Not the easiest thing to change, but with some help, not that big of a deal. Once completed, it started right up and ran fine.
                  The specifics: 2002 X-30, LTR 330HP, Carter pump #71-333S - CGB 98-002. For what it's worth, the NEW Mastercraft part number the guy gave me was 155193.
                  Thanks again for all the info provided in these posts
                    Glad it worked out for you. Keep us posted about an issues you may have. Did you reuse the plastic fuel line or did you replace it?
                    sigpic
                    Previous...
                    96 Prostar 205 Lt1
                    93 Prostar 205 HO
                      This is the disassembled Carter pump that came out of my boat. Makes you wonder if there is enough heat to melt the nylon around the + and - contacts, why the bomb doesn't go off. This pump was frozen and I wanted to know what seized it, there was no trash in the pump itself as it is still free, the nylon melted to the contacts.
                      I used an ORiley pump E2044 for replacement. Attaching it to the plastic fuel line is an PIA but with a little time it can be done. I have 4 hours on pump now and it works fine and pressure at the fuel rail is in spec with MC manual.
                      Hope this helps others as I cant believe with a pump that is cooled by fuel it pumps can get this hot and not be a manufacture issue.
                        Nice work. It does look like the problem might be specific to this carter pump. Lets hope our replacements work out a little better.
                        It makes me feel better not putting that same pump back into my boat, especially at $500 a pop!
                        sigpic
                        Previous...
                        96 Prostar 205 Lt1
                        93 Prostar 205 HO
                          Thanks for doing this guys. I know there are several here that really appreciate your hard work in sharing this info. (save thread)
                          Thanks !!!
                            Now I would love to see someone do a step-by-step "how to" for replacing this pump. Pictures would be great too.
                              Same dead fuel pump problem
                              I have a 2003 Xstar with 350 MCX, and had the died while idleing thing happen to me this weekend. My pump has the same 71-333s carter numbers that you have, and my pump MC part number is 155193 according the chart that boofer referenced in another thread (http://207.170.215.108/awweblive/Aww...IX%2099-07.pdf).
                              Did you use the ACDelco EP356 pump that was mentioned earlier in this thread. So far every one but you has had a different MC part number according to boofers chart than what my boat was calling for. I am just trying to confirm that the EP356 pump works in my fuel module also. Thanks for your help
