Just to get the submersible hose, I got another MC fuel pump module with a burned-up Carter fuel pump. Whole module was gonna be thrown away.
(a) the hose that comes with the Carter pump fuel module from MC is 1/4” on one end, and 5/16” on the other, and
(b) the aftermarket pumps have the same barb size as the Carters.
Hope this is helpful.
Stu
I think I've got some updated info.
Just to get the submersible hose, I got my hands on another MC fuel pump module with a burned-up Carter pump that was gonna be thrown away.
To harvest the ENTIRE hose, I had to destroy the barb on the burned-up Carter pump that came with the module I just picked. More on that below, but the this pump and my old Carter pump are identical, ("323 Made in USA"), with same sized barbs.
OK, in the 1st pic notice that the barb on my old Carter pump and the module barb are indeed different sizes. A 5/16" EFI hose fits perfectly on the Carter pump barb, while a 1/4" EFI hose fits perfectly on the module barb. You cannot IMO get a seal with a 5/16 EFI hose clamped on the module barb.
In the second pic notice that the harvested hose is set up for the different sized barbs on either end!
In the 3rd pic my original pump is on bottom, with the burned-up one I just picked up on top. The top hose is much more flexible and less likely to kink, but it is still heat welded on both ends, and you can't just pull it off.
It will be easier to reuse your old hose if it is like the one on the module I just picked up instead of like my old one. It's softer. To reuse it you can cut it, and go with a shorter hose, but the harvested hose seemed quite a bit shorter than my old hose was before I cut it in half -- and you need some extra in there -- so I cut the brass barb off the burned-up Carter pump I just picked up. Then I drilled the cut off barb from the inside till it started to spin inside the hose, then I crushed it a bit with pliers and was able to pull it out.
I hope this clears some things up. Thanks bigmac, rhsprostar, and other for your ongoing commitment to this cause. BTW, sorry about the overuse of the word "harvest." Great Neil Young album though!
Leave a comment:
