After a ton of online and in-store research, I think I've found a replacement fuel pump with the corrects specs for a 1999 LTR - the Delphi DFP FE0299 (this is a NAPA part number, I think). This pump has a PSI rating of 45, which fits into the 35 to 45 PSI window called for in my owner's manual. My only question is with respect to the pump's volume rating, which is listed as 27 gallons per hour. My manual calls for a volume rating of 1 pint per 20 seconds, which, if my math is correct, is 22.5 gallons per hour. So . . . do you think I'll be okay running a 27 gallons per hour pump even though the manual calls for 22.5? My guess is yes, but I wanted to run it by you guys.
Fuel pump aftermarket part numbers
Bump - Corbin thanks for posting the pic below. 450 hours - She done.Last edited by neil.anderson63; 06-15-2015, 11:01 PM.Screws fall out all the time, the world is an imperfect place.
Found it.
Neil cross referenced the airtex # to a precision pump (Since neither one of us like airtex stuff).
$90 at the local Orilley, used the clamps in the box.
Ended up saving his Powell trip having this as a spare.
Originally posted by mikeg205 View Postwhat are the specs on the that pump?
Fuel Pump Fitting Size[s] Outlet - 5/16
Fuel Pump Fitting Type[s] Inlet - Filter, Outlet - Hose Barb
Fuel Pump Gallons Per Hour 45
Fuel Pump Pressure Rating 90 - 100 psiThe Only Thing That You Can Give and Still Keep Is Your Word
Fuel Pump Pressure Rating 90 - 100 psisigpic...A bad day water skiing still beats a good day at work...1995 Pro Star 205....
Originally posted by trickskier View PostDoes anyone know if this Carter Fuel Pump will work on an MCX Engine?
[ATTACH]141273[/ATTACH]
[ATTACH]141274[/ATTACH]sigpic
04 197 TT LQ9 stargazer w/Z-Box
Tournament PB 1/4 buoy @ 35 off
Previous...
96 Prostar 205 Lt1
93 Prostar 205 HO
81 Leaves and stripes(Can. edition)
