Fuel pump aftermarket part numbers
  • Originally posted by stu View Post
    Rudaire, I think you are part of a "work in progress."
    ps, I wish I could be out on the water this wkend too. Throttle cable.
    OK.......we have a fix for that to!!!
    -The first thing you need is a a 7ft piece of lamp cord, some paperclips and a anglegrinder......
    sigpic
    04 197 TT LQ9 stargazer w/Z-Box
    Tournament PB 1/4 buoy @ 35 off
    Previous...
    96 Prostar 205 Lt1
    93 Prostar 205 HO
    81 Leaves and stripes(Can. edition)
    • Originally posted by rhsprostar View Post
      You know me, I need photos. I'm trying to picture it...just got the image im my mind!...
        Actually I devised a workaround.. Since my fuel tank isn't vented, I just use a 12 volt electric air pump to pump air into my fuel tank. I keep an eye on it, and try to keep it between 55 and 65 psi by cycling it on and off, but once it gets up to pressure it lasts for quite a while as the only way for the pressure to go down is for the fuel to be burned out of the tank. I've since removed my fuel pump, but make sure the fuel pick-up hose reaches the bottom of the tank.. The only real problem is the noise from the 12V air pump is annoying, and i can't use the rear cabin cigarette lighter to light my smokes after a hard run anymore since the air pump is plugged in there.. But at least I'm on the water!! and the air pumps sell for $30!!
        • Rudaire, you almost got me!
          • Originally posted by rudaire View Post
            I LIKE IT!!!
            Sounds like some serious consideration was put into that one!
            sigpic
            Previous...
            96 Prostar 205 Lt1
            93 Prostar 205 HO
            • Help!
              The pump died on my friend's 06 MCX.
              Wich replacement should do the job?
              Keep skiing!!!
              • Originally posted by André View Post
                Help!
                See this thread...
                '04 MariStar 230VRS/MCX
                • Originally posted by bigmac View Post
                  Funny Dr!
                  Just wanted to now if there was a specefic replacement for the MCX...
                  Keep skiing!!!
                    Funny Dr!
                    Just jokin' ya, Andre.
                    Nah...they're all going to be OK with the same pumps described here. Be careful with the in-tank hose, though. Apparently he's going to have to re-use the old one, so he either needs to be careful getting it off the old pump, or at least cut it as close to the barb on the pump as possible. No one has found a source of fuel line replacement, yet.
                    • I have a friend who just bought a new pump thru MC and after recieving it he found that it was
                      not the problem......FYI... MC's part number is 155183
                      Here is his contact info: Mark Davidson 402-301-9942
                      • Originally posted by BOATNGUYNE View Post
                        Good tip, although these threads have been about just replacing the fuel pump for $94 instead of the whole module for $441.
                        • I used the ac delco and autozone crossed it with their pump and 5/6 hours later all is good.
                          My fuel pickup line was like new I saw no reason to replace it. cut the clamp off and slid it off and slid it back on the new pump.
                          ___________________________________________
                          Originally posted by bturner2
                          Myself I'll live on the edge and surf without a helmet.
                          • Originally posted by TX.X-30 fan View Post
                            No problem getting the old 1/4 inch hose over the 5/16 barb on the pump?
                              My hose was spread from the old pump, i have no idea how they did it at the factory but I did not cut the hose just slid it off. I thought it was strange how that rigid hose was flared on the pump end but it slid right of with a little testosterone.
                                Help!
                                He did install NAPA E2065 ,now run fine but very hard to start...
                                He doubled checked the hose but says it,s fine.
                                I wasnt there for the repair...
                                Any ideas?
                                Keep skiing!!!
