Ford 351W photo of front of engine showing alternator set up
  • Ford 351W photo of front of engine showing alternator set up
    does anyone have a good clear photo of the front of a 351W Indmar from an 87-90 showing the alternator set up and alignment? My engine rebuilder failed to take a photo before he tore engine down and now is confused. Thanks
    Attached is a photo of the 93 year make of the Indmar 351W Ford engine. Should be the same as the 87-90. That is a newer single wire 105A output alternator.
    Never came back.
    93 190
    (safe click)
      Thanks Waterlogged!
        Thanks Waterlogged!
        At this pace, you'll have it done by 2025. lol : - ) <== because emoticons do not work...go figure
        Click image for larger version  Name:	engine 93.jpg Views:	0 Size:	123.3 KB ID:	2696419
        93 190
        (safe click)
          Only took 7 mos to finish the engine rebuild!
