Okay, I'm stuck. I've got a 2003 X10 with a predator 310. Upon startup I get a 1 minute alarm and check engine light. Oil pressure, temp and battery are good. I pulled the code 81 which to my understanding could be a lot of things from TPS to fuel pump. I've checked all connection for corrosion around the throttle body and all looked clean. What should I do next? Anyone have a similar issue?
Appreciate any and all help.
Also, before pulling the code o replaced the knock sensor as the old one was looking really rough.
