Hi everyone,
We have a 95 Prostar 190 with the 275 HP Indmar 350 engine. We love the boat and this Spring we just went to start the ol' girl and she did not start.
We pulled the flame arrestor and noticed 0 fuel coming off the injectors at crank, and also spraying starting starting fluid in the throttle body did not lead to any ignition. The fuel pump did prime each time.
Wrongly when not seeing any fuel, I assumed fuel pump. We replaced the fuel pump and fuel filter and did not change the situation.
We also did disconnect the lanyard and the fuel pump did not prime , so the lanyard switch was appearing to work as intended.
After some thought, I recalled that the MEFI-1 system gets a signal when the distributor turns (from the start turning it at start time) and that without that signal it may not tell the injectors to spray or spark to happen.
So I ended up replacing the distributor with one from Advance Auto for a 350 and the problem was solved.
I wanted to share since this is not a common issue.
We also checked fuses and connected my Diacom to the ECU and it responded so I knew the ECU and power to the ECU were good.
PM me if you want more details, but I hope this helps someone in the future.
Lastly, we replaced the fuel pump with one from Summit Racing so I ended up using the existing return line and just blocked the one input from the old pump fitting at the Y.
Pump is working great and boat is running 42-43 and pulling like it should.
Peace.
Peace.
