Hi from the UK
A friend of mine acquired 1998 Prostar with a standard gear box/transmission in Oct last year. At that time no issues. He has spent the winter improving its general cosmetic appearance and launched last weekend..
Engine runs perfectly but when putting into gear(forward or reverse) the transmission does not engage.
Checked the lever on the transmission itself and it is moving properly between the three positions. Have disconnected gear cable and confirmed lever is moving to full travel in forward and reverse selection.
The transmission safety when starting solenoid is working properly.
The transmission fluid is at the right level and clear in terms of condition.
In addition there is a two point terminal with relatively heavy duty white wire going off into the loom on top of transmission. What are they for?
Any suggestions on what to check next in terms of diagnosis before all the hassle of taking the transmission out.
All help appreciated.
Regards.
Regards.
