Originally posted by waterlogged882
View Post
Now I have a new issue with the carb. There’s what sounds like an air leak right around the carb base / diaphragm actuator. I had a new spare diaphragm and power valve, so I replaced both as well as a new carb intake gasket and still hear air sucking in pretty loud, which is causing a rough idle. Anything else around that area that would cause a loud air sucking noise? I plan to pull the carb off tomorrow and take a better look. I had like 5 back fires through the carb when the timing was off, so thinking maybe I blew a gasket in the carb somewhere?
I rebuilt the 4010 a few months ago due to the carb having idle issues. I took it apart, cleaned it good and used all new gaskets and the boat ran like a top at the time.
