Originally posted by dummy
View Post
2004 mcx 350 cam specs????
Originally posted by scottyb View PostHey guys,
I know I am going to need to adjust the fuel mapping for the 383. I was debating on sending my ecm in to get it mapped or purchasing the MEFI Burn software and tuning the computer myself via laptop in the boat using the real time engine data. The program is a little pricy but Will prob be worth it in the long run, having theability to make adjustments any time I want.
My only concern is if the stock injectors will be able to handle the amount of fuel needed.
Thank you
Scott
I'll look more at the other photos in a second and post about them.-Tim
Making boomers great again!!Boomin'
Originally posted by dummy View PostYeah, what could happen?
One of the long term issues I know about comes from watching others. Said motorhead put a HP310 HP small block in a standard 350/210 HP fuel system. It ran "fine" for a long time until the tops of pistons finally burned off.
The same thing happens with 383s that run 350 injectors.
We know you don't have a dyno. So when I ask who could burn a chip I wasn't talking about the average joe with a computer in his garage. I was talking about someone that burns chips professionally. You could try www.tbichips.com and see if he can do it or knows someone that can do it.-Tim
Originally posted by MYMC View PostAh the old superflow...I do miss it from time to time.
If it were me...and it's not...I call Alan Tehan (http://www.technicalservicesin.com/index.php) since he has done more MC "hotrodding" than most. He used to be on the MC payroll, but that is another story for a different day.
Originally posted by 92Maristar View PostThe stock injectors will not flow enough fuel. You will not know how much to change things. Just pay someone qualified to do the work. Your motor is worth to much to just guess. As you can see by the previous discussions it's not a seat of hte pants feel.
Originally posted by JimN View PostWhy won't they? Without knowing how much it needs, I don't think there's any reason to automatically decide they can't do the job when the easiest change to make is the pulse width. (This motor doesn't have a blower, does it? If it will get one, it'll need a different MAP sensor, too.)
You really dont want the duty cycle to be greater than 80% so the 24lbs injector may not be enough based on "guesstimated" HP. The other side of this is that the larger injector is much more difficult to control at idle...particularly given the set-up.
You could boost fuel pressure to make the 24lbs injector act bigger, but then you are getting into modified fuel systems on a boat...never a good thing.
Decisions decisions..."You do realize that a nutless monkey could do your job"
Les Grossman
Originally posted by JimN View PostWhy won't they? Without knowing how much it needs, I don't think there's any reason to automatically decide they can't do the job when the easiest change to make is the pulse width. (This motor doesn't have a blower, does it? If it will get one, it'll need a different MAP sensor, too.)-Tim
Originally posted by JimN View PostThat was more or less my point. I don't know exactly what the duty cycle is with the OEM program. As I said, there's no reason to just decide that they can't handle it out of hand and guessing isn't much good for this kind of situation.-Tim
Originally posted by 92Maristar View PostSo, Dummy, what is the story behind this piston?
