I have a 2001 Maristar 210 with the LTR 330 motor. Over last summer I was getting an intermittent misfire on cyl 7. Again intermittent. Sometimes it happens on start up, sometimes not. Sometimes it develops when we are out boarding or wakesurfing, but not every time. They is some light shaking at idle when it happens. I was successful in restarting the motor to clear the problem on most occasions.
Everything is up to spec with the maintenance. plugs, wires, filters (incld fuel). Grounds are all good and clean etc. I am suspecting this is a coil pack issue. its the only thing I can determine.
I talked with my dealer and the coil pack comes as an entire unit for all 8 cylinders, for the silly little price of $800. There has got to be a easier way. I talked to skidim and they suggested that I pull them and maybe source them individually from Accel or GM.
Anyone played around with the coil packs on this motor and have suggestions?
I am going to pull the coil packs out and see what I can find. Maybe I can shed some light on this for others.
BTW, the boat has 900hrs entirely in saltwater. Most likely a instigator in the problem.
