94 Prostar 205 is this the correct trans cooler
  • 94 Prostar 205 is this the correct trans cooler
    I just bought this boat 2 weeks ago and it had water in the trans fluid. I seemed to have gotten the water out but while suspecting the trans cooler was the issue I saw below. Is this normal? or did someone throw the wrong cooler in and then rigged it.
    The impeller hose goes over the cut hose pictured. Doesn't seem right to me
    2010 X-15
    SOLD 1994 205
    2011 Pathfinder
    2016 Ford Flex
    3 kids, a wife, and a boat dog
    1 kid in college
    The correct cooler will have connections for 1 1/4 ID hose on each end. The Indmar P/N is 495150.
    Engine Nut
    Indmar Marine Engines
    Power to the Sport
      Hey, Engine Nut, glad to see you posting.
      To the OP, that looks like a reasonable trans cooler, but I don't understand why the near end isn't connected to anything. Raw lake water is supposed to flow through from end-to-end and on to the motor, and the trans fluid goes in/out through the side connections. If this represents how you've run the boat, then I think:
      1. The PO must have rigged a 1-1/4" hose that bypasses the trans cooler (probably because it has a hole in it that's letting water into the transmission)
      2. The transmission isn't getting any cooling at all (no good!).
      1998 Maristar 200VRS
        Sorry if I wasn't clear I detached the hose to the impeller for picture purposes. The hose goes over the cut hose pictured.
        2010 X-15
        SOLD 1994 205
        2011 Pathfinder
        2016 Ford Flex
        1 kid in college
