LT-1 items 1996 PS 190
  • LT-1 items 1996 PS 190
    New to me, 480hr 1996 Prostar 190 LT-1. I am just trying to get my maintenance items together. I have gathered bits of info from other threads someone please confirm I am correct on these replacement items for the 96 LT-1:
    Oil-synthetic 20w-50 (boat runs in Minnesota waters)
    Spark plugs- AC MR43LTS gap (.045?????)
    Fuel Filter- AC GF-626
    Oil Filter- ????????????????
    Thank you
    Oil Filter – WIX 51061
    Fuel Filer – WIX 33481
    Fuel Filter (on tank) – WIX 33003(clear plastic) or 33482(metal)
    Edit: And yes, AC MR43LTS @ .045"
    '96 ProStar 205 SD LT-1
      should not have to do much... change the oil. and fuel filters.
      1998 ProStar 205 LT1
        I usually spare no expense when it comes to my boat, but I do cheap out on the oil. I just run a good quality 20W50 petroleum based oil and change it out about every 50 hours.
        http://www.mastercraft.com/photopost...er=2572&sort=1
        Need LT-1 parts?
        89058397 (pump outlet side)
          15W40 diesel oil is more than acceptable as well.
          Napa Wix 51069 or 1069 oil filter.
          What is the 51061? A larger filter?
          '06 X2 MCX
            Yes, it is longer.
              Originally posted by Table Rocker View Post
              Yes, it is longer.
              Damn, just bought a 1069 today.
              Oh well, only got 25hrs on the boat this yr anyway, don't need a better filter.
              '06 X2 MCX
