Ltr Possibly running rich
  • mikeg205
    replied
    hey swat any updates?
    Leave a comment:
  • JimN
    replied
    Originally posted by swatguy View Post
    Thanks for a the info. It was a very dry black.
    The exhaust isn't overwhelming. It's just more than it used to be. Where it wasn't even noticeable over the past few years I now can smell it during idle while on the platform getting ready to ride. I recently had my gas supply switch in that I was still able to run non ethanol up until this summer. Unfortunately that station closed so now I am stuck with the ethanol gas.
    If you don't idle for long before shutting it down, I would look at the ECT, then the engine grounds.
    Leave a comment:
  • swatguy
    replied
    Leave a comment:
  • JimN
    replied
    It was a black color
    Wet and black, or dry? Does the exhaust smell strongly of gas? If nothing is wrong, other than running rich, clean the flame arrestor. If that does nothing to help, remove the two-wire ECT and put it in hot water & measure the temperature of the water before measuring the resistance of the sender. If it's much more than 200 Ohms at 200°F, it's bad.
    Here's a chart-
    http://www.autozone.com/autozone/rep...00c1528006c544
    MODS- PLEASE MAKE THIS EASILY AVAILABLE!
    Leave a comment:
  • swatguy
    replied
    Leave a comment:
  • mikeg205
    replied
    Originally posted by JimN View Post
    What color? Black, brown, tan, white?
    Look for a sensor on one of the heads or on the block with one yellow wire and a black one. It's the only thing on the engine with those colors.
    +1 ^^ - thanks for all your posts JimN... I have learned a ton from reading from the University of JimN.
    Leave a comment:
  • JimN
    replied
    So finally getting around to tracking this down. My work schedule abruptly changed and haven't have much time.
    Where is the Ect located?
    My plugs barely have any discoloration just the tip of the ends had a very small amount of discoloration.
    Leave a comment:
  • swatguy
    replied
    Yup. Clean as I can get it. I never did the t stat swap yet if that's what your referring to
    Leave a comment:
  • mikeg205
    replied
    This maybe a really a dumb question... and if you did ignore my suggestion... spark arrestor clean?
    Leave a comment:
  • swatguy
    replied
    Leave a comment:
  • JimN
    replied
    What should I be looking for? They were new at the beginning of season. I let the old ones burn off the fog and stabil for 2 tanks an then put the new ac delco's in. I am not really an engine guru so forgive my ignorance. I do all my own maintainance and can pretty much swap parts, but as to the workings and internals......... That's way out of my league.
    Verify that the gap is correct. That's not something you want to assume because it can start out wrong, or if it was correct from the factory, it can be changed in transit if the carton was dropped.
    Leave a comment:
  • Thrall
    replied
    If it's running rich, the plugs will be black/sooty.
    Good burn is typically about a cardboard color brown.
    White is bad (lean).
    Leave a comment:
  • CruisinGA
    replied
    Pull them out and take a picture, post it here. There are also lots of photographic guides on the interwebs.
    Leave a comment:
  • swatguy
    replied
    Leave a comment:
  • CruisinGA
    replied
    Plugs will tell all when it comes to mixture.. have you looked at them?
    Leave a comment:
