hello all,
im a new member and recently bought a 1984 ss knowing it needed a lot of work. challange accepted. after working on this thing for a couple months im at a loss. fisrt ill tell you what i know has been done to the boat then ill tell you my problem.
rebuilt 351 windsor installed
new impellor
all new hoses and belts
new distributor cap and rotor and plugs
new fuel filter
rebuilt 4160 holley marine carburator
and timed the engine once
every time i change/replace something, we take it to the water to test it and always have the same issues.
i can get the boat to idle awesome. it sounds good, revs and relaxes on command. as soon as i put it in gear it boggs so bad and doesn't want to go anywhere. pumping the throttle doesn't help, nothing seems to work. then if i try to put it back in neutral, the engine dies. then it seems a little harder to get it to start again. im at my whits end
couple things i havent tried yet
replace coil
replace fuel pump
checked breather or anti-siphon valve
had a boating friend tell me my firing order may be off and causing the problem
basically im looking for some guidance, ideas, correct firing order? whatever anyone can spare. i would really like to get this thing running before evrything freezes over for the winter. please help.
thanks for your time
-jeff
new impellor
new fuel filter
replace coil
replace fuel pump
-jeff
