is this a marine starter
  • is this a marine starter
    just curious if this is a marine starter . this came on the boat when i purchased it .
    but i was curious if it actually was marine.
    1988 tristar 351 indmar
    sigpic
    you would need to take it out and see if the brushes are in an enclosed area. could as simple as a gasket and a cover....or as elaborate as a screen mesh at the vents.
      Doesn't look like a marine unit.
      sigpic
        thanks i guess i will have to take it out and look . scarey i have been using this for the past year.
        sigpic
          Looks exactly like the (marine) starter i had on a Pleasurecraft 351.
            its good to take it out and lube the bendix shaft and gear anyway...
              thanks guys i will take it out and look for sure ,hopefuly tomorrow
              sigpic
                its an easy thing to do.................................if you're a contortionist!
                http://weathersticker.wunderground.c.../Brunswick.gif
                  Mine is identical to that in my 85 S&S. I took my wifes compact mirror (shhhh) and there was a NAPA label on the under side.
                    looks identical to the one in my PS 190
                      Like mgorczak1 said, one would have to take it out and look at it to be sure.
                      sigpic
                        Mine came from the factory that way and has never been out so I have no reason to dought it is a marine starter
                          thanks guys .i didn't get it out yet i decided to take the boat out on the lake instead.
                          sigpic
                            .....It is now.
