Spark plug question for a 1988 351 indmar
  • Spark plug question for a 1988 351 indmar
    Question guys I was just at Walmart today and grabbed some spark plugs I guess I was not paying much attention and in a rush ,I grabbed autolite
    AP 24. Not just the 24. Will these
    Platinum ones still work fine
    I just noticed the difference as I went to gap them.
    sigpic
    From my recollection, you want to run the copper ones. The platinum will "work," but the temperature is not optimum.
    Previous: 1993 Prostar 205
    FAQ
    Be kind. Have fun.
      thanks i guess i will try them now that i opened a pack i did a search on autolite's website .
      for a ford 351 i think bronco and they recommend the plats .but also suggested the copper.
      shouldn't they be the correct heat range . just the platinum ones would last longer .?
      don't they both have copper core just different tips . oh well maybe someone else will have more input .
      cheers
      sigpic
        I can't recall the specifics, but I bought the platinum tips, asked about it on here, and based on the answer, returned them for the copper plugs. Good luck.
        FAQ
        Be kind. Have fun.
          Bought mine through skidim.
          GET WET:
          WATERSKI!
            thanks i will probably try them and just get the copper plugs also for next year after winterization
            cheers i will report back on the plats , my mechanic buddy firgures the plat should be fine .
            sigpic
              Copper is a better conductor, but platinum lasts a lot longer. The heat range on both is the same.
              Next time, save your money and stick with copper... but I wouldnt hesitate to use the platinums since youve already got them on hand.
                The plat plugs are still cheap at Walmart.
                Small update ran the boat with the plat plugs the last 5 outings and don't notice any difference. Boat ran great through out the full rpm range.
                sigpic
