Longtime listener first time caller. I have a leak in my exhaust that is pretty large. I am looking at replacing and have the old silent master and have seen alot of other posts on the subject but am still not sure which route to go. I am not sure if I can get the mufflers reglassed as I have seen in other posts so I am thinking about replacing them both (only one leaking). Skidim suggested 0912 http://www.skidim.com/prodinfo.asp?number=288-3001 that looks alot different that what is on there. They did say I may have to cut the exhaust black tubes which seems pretty thick and rigid.
1) would it be better to replace with new both sides?
2) anyone already replaced with the mufflers skidim suggested and are they a good solution?
3) do I need to take off the exhaust risers to replace them either way? Seems like its pretty tight and they dont have much flex if at all to even get them out?
Thanks in advance.
Jay
Thanks in advance.
Jay
