Spray down the engine's metal surfaces with silicone lubricant?
  • Spray down the engine's metal surfaces with silicone lubricant?
    One of the steps for winterization is to use silicone lubricant to protect the metal surfaces.
    Can anyone offer advice/instructions? Do you just spray everywhere or do you have to avoid getting it on wires, electronics and all the other stuff that the marine engine is basically wrapped in? Suggested brands? I would think you would not want to get any on the K&N air cleaner as it takes a particular oil.
    Thanks in advance.
    I love to travel, but hate to arrive. ~~ A. Einstein
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming, Wow! What a Ride! ~~ Hunter S. Thompson
    My wakeboard is calling, and I must go ride! ~~ Me
    It is better to light one small candle than to curse the darkness. ~~ Chinese fortune cookie
    I think mine is Prestone. Keep it away from the belts and try to avoid the wires. Just the metal surfaces.
    Previous: 1993 Prostar 205
    FAQ
    Be kind. Have fun.
      I was told by Joe at the old MC of Charlotte to spray everything with WD40 including hoses and wires. That it would protect everything but basically evaporate by spring. (Maybe not exactly evaporate, but it disappears)
        Top Kote
        I actually use Top Kote finishing spray. I use it on everything from my car motors to door jambs and etc... It will make anything look brand new. All I do is spray it all over everything, motor,wires and etc...
        I actually buy it by the case. A friend and I split it. Cost was around $6.00 a can.
          Thanks all. I'm going to have to think about how to do this best for my engine/boat. Plus being a v-drive it is all so fun to get access to. A lot of the wires are inside plastic conduit so not to worry there I guess. But some trouble spots would be for example the fuel injectors and the short segments of exposed wiring running to them. Maybe wrap things I want to protect with some plastic wrap (aka saran wrap). I did spray a small piece of cloth and was applying by hand but this will not get to all the places I want to get to. I got three months to obsess over this during the "off season".
          I have some silicone spray by PB Blaster but it is a pretty strong stream and if I were to use it I'm sure it would splash over everything. I have to see what is available at hardware, auto, etc stores. I seen some stuff by Permatex online; I should be able to find that local. I think I'll give that a shot next to see if it is a fine spray.
          I guess I need to buy some of those long stick-ed cotton swabs as well to clean up any pooling in difficult to reach areas. And to think I use to make fun of my brother who cleans his motorcycle by dismantling it, cleaning each individual piece and re-assembling it.
            Spray the hell out of it with wd40 and forget about it. You are over thinking this.
              ^ What I do!
              I was njskier on here.
                I hit the linkage and any moving parts with the fogging oil I'm using at the time. The rest of the engine and vDrive with WD40. In the spring I wipe everything down while checking all the hose clamps and connectors to ensure everything is ready for the summer and to make sure nothing got missed when storing it up. This process has worked for me on everything from outboards to inboards over the past 20 years. Time for more spraying and less thinking.
                  Wd-40
                  I've used WD-40 too and still do if I'm out of TOP Kote. Top Kote is just a lot lighter oil than wd-40.
                  Plus top-kote smells so good!!! You'll be hooked on it if you ever use it.
                    I'll have to look up top kote, sounds interesting.
                    Yeah, WD40 or even Armor All type dressings work well. Just dust everything with it and call it good. Same with underhood on the vehicles.
                    For exposed to the elements or corrosive areas, Fluid Film works great. It's lanolin based. I use it mainly on my sleds since they're basically stored in a tin can (trailer), lots of condensation/moisture. Keeps snow from sticking as much too.
                    I would use that stuff if the boat is stored outside. If stored inside, it's not necessary as it leaves a much heavier film on everything.
                    '06 X2 MCX
                      Another vote for WD-40... remember it is called water displacement for a reason...
                      sigpic1996 Prostar 205 LT-1
                        I've used both WD-40, Boeshield T-9, and Corrosion-X depending upon how much residual film I felt was needed.
                        Ballistol is a product I've been reading about from a website that I purchase off-road gear from sometimes - read down to the steel wool-in-water test - it's pretty interesting stuff, but I've not ordered...yet.
                        Link:
                        I've also started using Motorex Joker440 in cases where I'd used WD-40, it's a synthetic based spray lube. This youtube video isn't something I'd condone but is pretty convincing that it does not conduct electricity and is pretty waterproof
                          Spraying Engine etc
                          Do you guys that are spraying WD40 etc store your boats inside? I keep mine in the garage and never spray the engine etc and do not have any rust or problems. Just Curious.
                          Love my boat, hate my trailer.
                            Yes...
                              Do you guys that are spraying WD40 etc store your boats inside? I keep mine in the garage and never spray the engine etc and do not have any rust or problems. Just Cuious.
                              Never sprayed a boat engine down in 30 yrs, but boats are always in a heated garage. I do wipe the dust off from time to time though. Engine looks like new. I also wash my car engines a couple times a year....
                              Currently schlepping on BIL's X46
                              MISS "B" HAVEN
                              2007 X2, Indmar 350 MCX (Sold)
                              OJ 522 14.75 x 15.5
                              Tugger: 2014 Ram 1500 Crew, EcoDiesel
                              http://www.crowniehq.net
