My engine in '89 Tristar never gets much past 140 to 145 deg after running constantly at about 2500 rpm's. Does that seem normal for this engine? I thought I should be running closer to 160 constantly? If that seems cold, I'm guessing start by checking gauge, then sensor, then thermostats, right...
'89 351 Indmar constantly 140 degrees
Originally posted by homer12 View PostMy engine in '89 Tristar never gets much past 140 to 145 deg after running constantly at about 2500 rpm's. Does that seem normal for this engine? I thought I should be running closer to 160 constantly? If that seems cold, I'm guessing start by checking gauge, then sensor, then thermostats, right...Engine Nut
Indmar Marine Engines
Power to the Sport
Originally posted by homer12 View PostWell, I've never touched the thermostat so probably time to check. This would be the one on top of the water pump right? Is it a 143 or 160 t-stat to be sure?/spôrk/
Originally posted by homer12 View PostThen any harm in running 140deg? I don't understand what damage or harm could be done by running a cooler engine. Looks like according to Bakes it may just be more efficient around 160deg/spôrk/
The existing gasket never survives to be used again. The gasket is cheap, so get one with the new stat, and apply a little silicone to both sides of the gasket to keep it in place and prevent any leaks. And don't over-tighten the housing.CUSTOM WHEEL & TIRE PACKAGES
sigpic
Email - [email protected]
