Hey all,
Ran the boat out of gas and burnt up the fuel pump. I replaced it with an E2044 which is what i had seen other people online using. I believe it should be spec'd at a max of 100psi. I am worried that maybe the flow rate is not high enough? We replaced... ran the boat and I am only seeing about 50psi at the fuel rail and i am not getting fuel power out of the engine. Can someone please confirm what fuel pump should be in this thing? If that pump is correct what else could be causing this?
Thanks,
Matt
Thanks,
Matt
