Removing Transmission Advice
  • #46
    Originally posted by milehigh970 View Post
    Loosen these on each side and you can slide the motor/Trans one way or the other. The large nut is for up and down adjustment.
    Thanks.
    The problem I'm having is that I thought you loosened the large jam nuts on the transmission mounts, and then turned the top nut to raise or lower the rear of the transmission... but even with the large nuts backed off, turning the small top nut is nearly impossible in either direction. It feels like it's bound up, and then when you turn it, you're flexing the rubber mounts, not actually turning the bolt. Am I doing it correctly and it's just "stuck", or am I missing something?
    • #47
      Nevermind.... I figured it out. Just gummed right up. A few hours soak in some penetrating oil and a little (lot) of elbow grease and the mounts are adjusting freely.
