I’ve got a 1994 ProStar 190 with an Indmar Chevy 350 TBI. There are three sensors/switches dealing with the raw water cooling it – one for the engine control module, one for the temperature gauge, and one for the engine overheat light.
The one for the engine overheat light is a 1/8 NPT switch mounted up high in the front of the engine near the thermostat. I’ve got a new one that is supposedly an Indmar part that doesn’t close when exposed to boiling water for two minutes. That’s based on three test trials using two multi-meters looking for continuity. I’m not sure of the Indmar part number, but the new one is stamped 35423-49 122. The one being replaced is stamped 35423-49 283.
Clymer’s manual for 1983-2003 GM V-8 inboard engines states the engine overheat switch should close 190-200 degrees F and should open back up 150-170 degrees F.
Can anybody here shed any light on whether I have the correct replacement part? Anybody disagree with Clymer’s temps, which if correct seem to indicate I’ve either got the wrong part or a malfunctioning part (assuming two minutes at temp should be sufficient to close the switch)?
