Below is the interior of the raw water pump on the 350 TBI on my 1994 190 I purchased last year. Am I missing a brass washer in there? I don't see one.
Engine Nut has posted instructions for a water pump rebuild that calls for a brass washer on the splined shaft and behind the impeller, but I'm not sure if that applies to my particular pump. Somebody else noted on the forum several years ago they had never seen a brass washer on the water pump on their LT1, but a resolution was not publicly posted as near as I can tell.
While replacing an intact impeller on this boat, I just discovered a broken piece of a previous impeller lodged in the intake of this raw water pump (see second photo below), so I can't just trust that everything is put together properly.
Any help would be appeciated as I'm trying to launch this thing tomorrow.
