took boat out today after leaving sand bar it ran hot. motor stalled and sputtered a little so I shut down. then seen steam coming from back of boat at water . sure enough when I turned the key back on temp gauge was pegged at 240. swam under to see if anything was stuck to thru hull ( no ) started engine up again it purred but temp didn't go down, so shut it rightback off. belt was still on. so Im guessing its the impeller. didn't change it before running it. first time its been on the water in two years. our river has been yuck. I have two questions:
What is the impeller I need from skidim? its been a while since I bought one. I have one here in the package, but it doesn't match their numbers. the one I have here. is pleasurecraft RP061018.
Second question:
Could the short time of running hot have damaged my hoses or muffler.
Its a 1999 X-star with the LTR 330 hp engine.
Thanks for any info.
and yes I know I should have changed the impeller before taking it on the first run. ( im an idiot )
Second question:
