Originally posted by nascar
View Post
Eithe pump for PCM or Indmar will work. the driver here is the configuration of the hard fuel line from the pump to the carb. If you are replacing the pump wit the water esperator, that is the Indmar route. You can use the PCM pump with a accompanying new fuel line (configured to meet the different outlet location on the pump]. Call and talk to the man at skidim. I have used both secnarios wit sgood luck
Leave a comment:
