4160 carb
  • 4160 carb
    Just took off the front bowl and expected to have gas spilling out and was totally dry. Had been sitting all winter. Is this normal. Needle and seat spotless float was set to proper setting. Last fall was having problems with front dripping and flooding out at idle. Is there any thing else to check? would adjusting the float to stop the fuel a little sooner help with this condition?
    1981 stars and stripes -powerslot
    sand with red metalflake stripe
    That's not normal. Yes, you may need to lower the float if you're flooding at idle.
    Don't forget that when you're on the trailer, keep the boat level. If you use the jack and put the nose too high, you may be flooding out in a position that would not normally flood on the lake.
    The only thing I can think that might drain your primary float bowl is a ruptured power valve (it would drain into the intake manifold). This would also create a rich condition at idle, so that may have been your problem all along (and not a high float).
      If you were having dripping issues, the needle and seat weren't making good enough contact to close. It doesn't take much for them to seep.
      sigpic
        Recently I have seen a few power valves that were not ruptured, but seeped a small amount of fuel. I suspect this carb is in need of a rebuild.
        sigpic
          just rebuilt the carb.. Only has about 10 hours run time.
            If it were mine, I would pop in a new needle & seat, as well as a new power valve, and double check the float. But I have those parts on the shelf so it makes it simple.
            sigpic
              If you turn the bowl upside bowl and blow through the inlet... can you? You may have rebuilt the carb but there is always a chance some crud made it's way in there and is keeping it open.
                Just tried to blow through the inlet. Needle closed off 100%. Cant be leaking from there.
                  Well the next step is to test your power valve, but that's not really very easy. Do you have Amazon Prime? You can have a new Power Valve in time for the weekend.
                  http://www.amazon.com/Holley-125-65-....5+power+valve
                  If you suspect your PV was blown, and since you have an older 4160 presumably, I would order this at the same time. It will protect your new PV in the case of a back-fire.
                  http://www.amazon.com/Holley-125-500.../dp/B00029JAPU
                    Power valve is ok. Installed kit when I rebuilt carb.
                      That's a bold statement. It could be new-but-defective, or blown with a backfire.
                      Unless your metering block is warped and allowing gas to seep through, there is not much else that explains a dry bowl in the spring.
                        Will check power valve. If I did have a back fire the kit should have prevented the power valve from blowing. Also I have mics and toolmakers square to check for warpage.
                          Bad gasket or leftover piece of crud from previous gasket.
                          sigpic
                            Yeah, but do you have the blowout preventer kit? I don't think those were standard issue until 1992 carbs and later.
                            Whatever it is, I hope you're able to find it. I know it's frustrating to chase a rich idle issue.
                              yes, I installed a back fire preventer kit when I rebuilt the carb. It is very frustrating when the boat stalls all the time when trying to pull skiers.
