Is you dipstick inaccurate?
  • Is you dipstick inaccurate?
    Hey guys I know this has been talked about in the past but I have to rekindle this topic. I have a 1991 351W engine and when I changed the oil last time I waited several hours before refilling. Yes I have the oil hose on the oil pan to help with this effort. I bought a standard Fram oil filter and filled with 5 quarts and noticed the engine read above the safe line after a quick start up. Have you guys with the same vintage engine experienced this condition? Are the dipsticks for this vintage engine and model known to have the wrong dipstick? Also my dipstick has a black coated tip and not sure what that is but it will not come off. Looks like a crinkle finish factory coating of some kind. Its only extends about 1/2" from the tip.
    I heard a rumor that some of the 351s of that era showed up with the wrong dipstick. I did some hunting to confirm the correct part number with a MC dealer on the dip stick at one point or another. For my 93 351HO, the part number was D5UE 6750 AF Ford M.
    Previous: 1993 Prostar 205
    FAQ
    Be kind. Have fun.
      I keep reading this issue, if I remember I'll measure mine. Oh and don't use fram, they have a tendency to collapse.
        Wow. That's news to me. I have used Fram for years with no issues in my car.
          ......... filled with 5 quarts .
          Over fill of oil. Measuring stick withstanding....They do not require 5 quarts.
          93 190
          (safe click)
          John 14:6
          (safe click)
            Well I checked the part number of my dipstick and it is the correct number that being D5UE 6750 AF Ford M. In the end she was 1 quart too much. Maybe she'll go faster now LOL
              /spĂ´rk/
                Originally posted by [email protected] View Post
                ^^^^ what cloaked said...capacity per manual 4 qts. plus maybe a little for filter. Also needs to be measured level as it sits in the water.
                Correct. All the more reason for changing oil at 50 hours. Oops........did I start another discussion?
                sigpic
                  Not sure I agree with the 4 qts. On my '93 351W HO I initially measured what came out and put the same amount back in. It was to the line on the dipstick and it was just shy of 4 qts. Next time out I was getting a slight lifter ticking noise. Put another quart in and no more noise. After that, every change was with 5 qts of Mobil 1 15W-50. Had over 1000 hours and still going strong. I just scratched a new mark in the dipstick and used that to check.
                  Never heard of an old school V8 motor that took less than 5 qts...
                    X2 exactly what i did mine will tick also with less oil ,my dipstick reads wrong also scratched a new line 19 88 351 same dipstick part number
                    sigpic
                      Kind of crazy being able to get 5 quarts in for me. I have always measured what comes out and put back same and always right around 4 quarts for me. That includes measuring what came out of the filter.
                        93 190
                        (safe click)
                        John 14:6
                        (safe click)
                          Just changed the oil in my 93 351 ho for the first time. 4 qts barely made it touch the dipstick. Right in the area of "add". Put the fifth quart in to put it in the " safe " area.
                            well Peter - if you use synth - I bet you could squeeze a good 10-15 extra hours out of oil... liquid engineering and all - better base oils.. better additives..
                              93 190
                              (safe click)
                              John 14:6
                              (safe click)
