1987 Indmar 351w bogs/hesitates upon accelerration
  • 1987 Indmar 351w bogs/hesitates upon accelerration
    87 indmar 351w with holley 4160 bogs under loaded acceleration. This usually occurs when the boat is warm and trying to pull a skier out. When I am in the cockpit I can ease the throttle and get a skier out, but less experienced drivers have issues.
    I have rebuilt the carb and replaced throttle cable, plugs, cap, rotor, checked and adjusted timing, fuel filter, adjusted accelerator pump, fuel nozzle, choke, new adjustable secondary etc... Engine is strong
    I have read in a few similar posts that I should check for weak fuel line which I will get into. Still looking at carb, but I think its working well.
    Any other ideas?
    Check your filter under your fuel pump...
      How does it behave running WOT? I suspect OK, in which case I would look at the accelerator pump function. The passages for the accelerator pump are quite small and if not completely clean, they will cause a stumble.
      sigpic
        replaced fuel filter this season. took the boat out for a few laps today and ran fine. I what would cause an intermittent condition?
          Any other ideas?
          Do you have a vacuum gauge? Monitor that when it's loaded and accelerating- if you're opening the throttle far enough, it'll be too rich when the engine is at normal operating temperature. Might need re-jetting.
            "wonder what"
              re-jetted when carb rebuilt this season.
                "wonder what"
                Huh????
                  Did you have this problem before you rebuilt your carb?
                  Why did you re-jet?
                  What were previous jets?
                  What did you change to?
                  Did you use a Holley marine rebuild kit?
                  How did you clean your carb during the rebuild process?
                  sigpic
                    /spĂ´rk/
                      cleaned carb with gumout. re jetted because i had it open and replaced with stock. replaced floats: adjusted parallel to fuel bowl, Ski-dim kit, substituted stock power valve with quick fuel 2.5.
                      ill have to pick up a cam kit. I did notice that the fuel line coming from the top of tank makes a hard 90 degree angle into the bilge. I am going to work on making a smoother bend in the line. The fuel line could definitely be pinched off slightly.
                      Been running well today. havent pulled a skier though...
                        This doesn't sound like a fuel supply issue, otherwise there would be problems with overall hard runs and pulling a skier.
                        Hesitation under load isn't always a carb related issue. I would check the voltage at the positive side of the coil both with the key on/engine off, and with the engine running. Points or electronic ignition?
                        sigpic
                          93 190
                          (safe click)
                          John 14:6
                          (safe click)
                            points, havent rebuilt distrib
                            but installed new coil, plugs, cap, rotor a few weeks ago
                            have the quick fuel adjustable secondary, hull is clean.
