Today I took the boat out to test two props at Acme's request. One is the 3-blade #1413 and the other is the 4-blade #537. Both props performed admirably and had their pro's and con's. Here are the results:
CNC 3-blade #1413 13.5 x 15.5
WOT 4750 RPM @ 37.8 MPH---- Cruising 3 Hg vacuum 4250 RPM @ 35 MPH----21 secs to top speed
. Tad more vibration
. Hole shot not as powerful as 4-blade
. Steering in to turns easier
. At cruising the bow is rock steady at about 6-8 degrees
CNC 4-blade #537 13.5 x 16
WOT 4500 RPM @ 38.2 MPH---- Cruising 3 Hg vacuum 4050 RPM @ 35 MPH----16 secs to top speed
. No vibration and smooth
. Much better hole shot
. Steering is very hard left or right. Even notice it slightly harder in gear at 600 RPM
. At cruising bow is not as steady and will porpoise up down tightly averaging about 8-10 degrees
I really wanted that 4-blade to work out. The hole shot was incredible especially with my power slot transmission and its time to top speed was better as well. Keep in mind the 3-blade was not a shabby performer either. It was so close on some issues I had to do the test three times today. However the deal breaker was the hard steering. That 4-blade must be pushing a fierce column of water past the rudder and it's resisting movement. The 3-blade prop was fine for steering. And yes I have a brand new steering cable and its greased. The rudder was torn down and cleaned and greased and it has acceptable play from what I have researched. So I ask everyone, is it normal to have harder steering with a 4-blade prop? Its hard enough that I don't think my wife would be able to turn the wheel past six inches before she would give up. For me it took some strength to overcome the hard steering past 6-8 inches of steering wheel movement.
