Just wondering who the source is for rudder ports. Even Skidim doesn't list any.
Where can you buy rudder ports?
You talking about the rudder log? If so, Glenwood Marine is a good source. They have a great online catalog - very comprehensive.
www.glenwoodmarine.com
We sell the bushings and seals we installed in our original ports we made. We also will rebuild our ports with new internals if needed. As I said when you called, the fix for the older ports with o-rings is new o-rings and grease.
Originally posted by EJ OJPROP View PostWe sell the bushings and seals we installed in our original ports we made. We also will rebuild our ports with new internals if needed. As I said when you called, the fix for the older ports with o-rings is new o-rings and grease.
[QUOTE=EJ OJPROP;1183014]We sell the bushings and seals we installed in our original ports we made. We also will rebuild our ports with new internals if needed. As I said when you called, the fix for the older ports with o-rings is new o-rings and grease.[/QUOTE
Thanks for clarifying that Eric
