reverse rot. 302 Holman Moody timing cover
  • reverse rot. 302 Holman Moody timing cover
    Hey, while rebuilding the 302 ford holman moody reverse rotation for our 1975 Stars and Stripes we noticed a crack in the front timing cover. The pin for the fuel pump cog came loose and galled the cover but also we noticed a crack right through. The guy that did my machining work said he thinks he has a couple 302 covers, but they are aluminum. Would it be ok to replace the cast iron one with an aluminum? He wasn't sure since it was marine if that was OK.
    If not, does anyone know where I could get a cast iron one, or what engine might have this same one?
    Thanks
    Nothing marine specific on the timing cover. You are good to go.
    sigpic
