91 tri star trany fluid change
  • 91 tri star trany fluid change
    I apologize if this question has already been asked but I could not find it. Does anyone out there know the exact amount of transmission fluid to change in the 1991 Tri-Star 351 Windsor with velvet drive ratio 1 to 1? I feel like I have check the web for the last week and not come upon a clear answer.
    Two quarts.
      I always measured what I was able to get out and replaced with that amount.
      1989 Tristar 190 - Indmar 351, 250HP, 1:1, 580 hours
        Remove as much fluid as you can with a vacuum pump, then replace the same amount. Warm up the tranny, check the level with the dipstick, add additional fluid if needed.
        I found that with my '92 I need to keep it completely full (according to the dipstick) or it will occasionally slip. Slippage usually occurs under hard acceleration or sharp turns to the right.
          That's what I do, too.
            here is a pic from the tristar owners manual for future reference . manual can be downloaded from this site also if you want it
            2qt
            sigpic
