I am working on resurrecting this boat. So far I have checked out the engine. Installed new strut bushings and put in a new ZF transmission. It has a 5.7L GM Indmar engine.
Everything is ready to start up but there is no fuel coming out of the fuel pump. This boat has an external electric fuel pump mounted on the bell housing. When the key is turned on you can hear the pump prime for 3 seconds like it is supposed to. With my thumb over the outlet I cannot feel any pressure or suction. The fuel tank is full.
The engine will start on starting fluid.
Has anyone ever had a situation where the fuel pump runs but does not pump fuel? Does anyone know whether it matters which way the wires are connected on the pump. They have been spliced before. There is no (+) or (-) on the pump.
