Last shop I went to that dewinterized the motor; stripped the drain plug threads in the manifold to the starboard side and fixed via JB Weld. So obviously that has to be replaced in order for it to be winterized this fall. My question is this...do DIY? Im not very knowledgeable with engine repair (particularly marine engine), but from what I can tell; it doesn't look all that complex (youtube). Obviously I don't want to ruin the motor and I know how youtube can give you a false sense of security, so I am asking for input as to whether this is something I should tackle or go with a pro. Its not a money thing, but more of a I would like to know how to fix my own boat thing. I know to be careful about getting debris down in the ports when I remove the manifold, but any thoughts would be appreciated.
Also, If I replace one manifold and riser; should I go ahead and replace both?
