Tried to take the boat out for a cruise and would not start. I changed plugs, coil, ignition module, wires, and distributor, still nothing. Hooked up spark plug tester, no spark on all 8 cylinders. Checked the coil for spark, none.
I have fuel pressure, hooked up fuel pressure gauge to schrader valve, 60 psi.
Checked kill switch and all wires from batteries, everything is tight and connected.
What else can I try or look into?
Thanks, Skiman
Thanks, Skiman
