I have an overheating issue with my X2.
At idle, everything is good. I have water circulation (I can see water movement in the strainer) and the temperature is 165 F. I take is out on the lake and increase the rpms and the strainer empties and the engine heats up (200 F). I've removed the raw water pump impeller and it looks good. Thinking the next steps are to replace the impeller and thermostat. Any other suggestions?
