I have a 1998 Prostar 190 with a LT1 engine. The fuel pump is whining something fierce and I want to be prepared for the inevitable failure.
I'm told the original fuel pump has not been available for the last year or so. I called Skidim and they recommended the following:
http://www.skidim.com/FUEL-PUMP-KIT-...tinfo/49-5117/
The problem is that's a $464 part.
I've been scouring the posts on this topic and I see some are replacing the original with a Carter P5000 like this one:
https://www.summitracing.com/parts/crt-p5000
At about $100 the Carter is a much better option financially but I also realize you get what you pay for.
Is it worth it to get the Indmar pump from Skidom or go with the less expensive alternative?
Thanks in advance for your comments and recommendations!
