Got the new circuit breaker installed and got the spark tester. Does it need to go to a cool or to a spark plug like I have it? Same deal, engine cranks but doesn't start. The spark tester is not lighting up when I crank it, but I clearly had fuel pressure yesterday. I tried swapping the crank sensor plugs too and no change.
LTR 330 won't start
https://www.mastercraft.com/teamtalk...ad.php?t=66772
Came across that thread and nearly same not and problem, only I don't have an x star that I can pull relays from.
Originally posted by Jcbrdnbrg88 View PostI found this 50 amp red push button fuse at the back of the engine near the ecm. It seems to be popped out and won't push back in, but seems more spring loaded than a normal fuse. Any way to test it?
Originally posted by Jcbrdnbrg88 View PostI used a fuse tester for all of the three little blue 15 amp fuses and all checked out. So the red 50 amp push button fuse is okay then?
Once it resets, it should close and carry the load.
Based on what I have found, it must be one of:
-ignition module (https://www.mastercraft.com/teamtalk...t=70214&page=3)
-one of the 3 relays by the ecm (https://www.mastercraft.com/teamtalk...ad.php?t=66772)
-bad crank position sensor
Not sure how to troubleshoot any of these issues, other than using and ohm meter to check the resistance on the relays.
Originally posted by bcd View PostHere's a picture of my fittings
Question regarding the middle PVC piece. Does that fit the garden hose attachment off of the shelf or did you have to thread that?
Great idea, so over the whole bucket method.Kevin
Been out of town, but from what I gather he fuel pump is priming the system but you don't have spark. Call your local parts store and see if they can check an ignition module for a GM. Like a 98 Cadillac. They should be able to verify the condition of the ignition module. If it's bad you know what to buy. Of it's good then one of the crankshaft position sensors has gone bad. If you replace them make sure you check the gap between the sensor and the crank. If you only buy one just replace one and see if it will start. If it won't start replace the other one with the sensor you just took out.1986 Marlin Magnum Skiier-sold
1999 Maristar 210VRS-weekend ride
1996 205 with LT1 cracked block-stitched back together
