Took the ignition module to auto zone. Tested it 6 times and checked out okay. It has to be the cam/crank sensors or the three relays back by the ecm? Any way to test either of these before throwing parts at them? I read on a post from JimN: "If you ever need to check this type of relay, use a multi-meter and set it to comtinuity- Measure across tabs 85 and 86- you should see resistance in the area of 80 Ohms. If it's a little more, it doesn't matter as long as the relay latches when voltage is applied to these terminals. If it's open or shows little/no resistance, replace the relay."
Any way to test the crank or cam sensors before replacing them?
