That is a good question. I did not know anything about the IAC before they called to tell me about it. After searching through this forum I saw some posts about them fouling up and that they need cleaned every now and again. At first he told me the IAC was sending bad signals to the engine computer, but after hearing that the spark plugs were fouled, maybe the IAC wasn't bad but just fouled.
LTR 330 won't start
I had the same problem early this year. Found the issue was the connections under the back cover where we all put our skis. There are 3 connectors under there right on top of the fuel pump. There was no sign what so ever of corrosion, but I cleaned them anyways. I cleaned them with some electrical spray, I use DeixIT and my LTR330 has fired up first time every time all this year. Hope this helps!2001 ProStar 190 330hp LTR
