'12 X25 perfect pass
  • '12 X25 perfect pass
    I have a 2012 X25 and when I sit my perfect pass to 11 MPH or so I will hammer it when I take off and it takes off well then it kind of slows down then it picks back up to reach the 11 MPH. It takes awhile to do this. Is this normal?
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Explain awhile how weighted are you and what prop do you have? i Used to take my 12 x25 to 4k in ballast and it would take a minute to settle but when i proper to the acme 1285 it held better and got to speed faster. Have you played with your PP settings? or called perfect pass? you can also upgrade to Zero Off and it supposedly holds better.
    2012 MC X-25
      I have about 3500 lbs. Don't know what prop it has on it. it takes about 30 seconds or so. It just jumps around a little bit on take off. Starts off fast to about 9 or 10 mph then slows down then picks back up to get to 11. Once there it's pretty solid. Just didn't know if there was a trick to it
        Definitely the amount of ballast
        Aric
        LONE STAR MASTERBASH 2022
        Register Here
        2019 XT22 - Ear Bleeder
        2022 Sea Hunt BX22 CC
        For Sale:
        2020 Crest 240 SLC Tri Toon
          Ok. Thanks for the help. That's what I figured. It looks like u post a lot and know a lot about 25s. How good is ur surf on ur port side. Mine isn't near as good as starboard side. I have a post in the wakesurfing folder on here if u want to see my specifics.
            30 seconds with that weight is about right. If it stays solid when you hit it then your doing about the beat you can.
            2012 MC X-25
